How accurate is willtheyfit.com?
Not all tires are alike. Some run wider than others even if they share the same specs. The picture that outputs after you put in the specs is a generic one. It let's us know that the tire could potentially be pinched, run square, or be stretched on a given wheel width. If you really want to see how a tire fits on a wheel I would Google image search it. There is a wheel/tire website that actually shows user submitted pics but I can't remember the name of it. Perhaps someone can chime in.
http://tyrestretch.com/
Also, I generally keep it "accurate" by comparing in my head to what brand/model tire I'm currently running and keeping that consistent. There is no way to figure things out 100% before you buy something. There is at least 5% figuring out what is going to work for you when you get the wheels.
I find it pretty accurate from a numbers standpoint. I'm generally using it just to compare the difference of running the exact same tire on two different sized wheels. When you throw different brand/model tires in I'm not sure how completely accurate it could be. A 255 RS3 is going to be much wider than a 255 all season.
