How about longer life, lower cost, and some dry grip?
Old 05-21-2003 | 01:42 PM
alex@tirerack's Avatar
Randy
I feel that you'd be loosing performace in lateral corenring grip.
The fuction of a longer lasting tire, is rubber that conforms less to the surface of the road. Compaired to the J spec S02 that comply very well to the road's surface.
As a benchmark,I think 25% loss in cornering grip. However is should be evaluated on a specific tire basis.
I feel that turn is is correlated to sidewall ridgidity, not a function of rubber's durometer (or softness). If your allseason tires were also W speed rated your turn in respoince should be nearly equal.
Now once your turned in, you'll feel the diffrence, around the skidpad for example.
Alex
Old 05-21-2003 | 08:12 PM
S2kRob's Avatar
I'd be willing to bet the Bridgestone RE-01 would offer similar if not better performance than the stock S02. Of course, they are only available in Japan.
Old 05-21-2003 | 09:38 PM
SDickson's Avatar
Here are a few other options that were not mentioned by anyone else, these are all available in the 225/50/16, along with 245/45/16.
Hankook Ventus K102
Continental SportContact
Dunlop Sport 5000
Falken GR Beta FK-451
Yokohama AVS ES100
Check out Tires.com for prices
Old 05-25-2003 | 10:52 AM
dolebludger's Avatar
Help, please!
My '01 s2k has 8500 miles on her and her OEM S 02 tires. I guess I'm lucky, as they are only starting to show wear, not worn out. But, time is here to start thinking about replacements. I have literally 1000 questions, which I will not ask all at once. But here's a few. Why do we need to go to a larger rear tire when changing brands? Could we go to a V or Z rated tire and do any better with treadwear and not loose traction? (Note, I had some Michelin V's on my old tricked Eagle Talon turbo with sidewalls so stiff they were literally "run flat" and got 40,000 miles!). Finally, I frankly found the OEMs to be a bit noisy. What would be quieter?
Thanks,
Richard
yungjoc
05-03-2007 12:11 PM
ALS2K
09-23-2005 07:42 PM
Tugz_S2K
01-18-2004 04:31 AM
Squeezer
10-16-2001 11:21 AM
GameDev
07-03-2001 09:59 AM
