Hope I can make these fit
Please could someone tell me if these would fit?
8J fronts & 9J rears offset 38 all round
Standard springs for now, coilies coming soon
Thanks
Thanks
roll, more aggressive pull, fender tab relocation, and -3.0 camber all around. You can safely fit 225/245.
+38 is the absolute limit on offset - definitely not ideal, but in that width, it will still work.
No pulling needed, just roll the fenders all around and rear tab relocate. Run the appropriate camber for the size tires you run. More tire means more camber in this case, since your running at the threshold of fitment. Id recommend sticking with a 215 up front.
