Honda Wheel locks
Honda Wheel locks
I bought some wheel locks from Honda. They gave me some locks but when I put them on the car they stick out a little more than the regular lug nuts. Is there different sizes?
Yes! there is a short length and long length lug nut. It all depends on the depth of the wheel socket. The S has a shallow socket on the wheel compare to the Accord/Ody/Pilot.
I did remove my wheel locks from my RDX which originaly were on my wife's first Ody. It fit flush on the Ody and RDX, but when I move it to the S2k it was sticking out a bit compare to the oem lugs. Its not a problem but cosmetically speaking it can be somewhat tacky. I personally dont care, at least no one can walk away with my wheels.
They discontinuted the "short" locks. now all Honda Cars run the same lock, so yes - the lock does stick out further than the others. The Pilot, Odyssey and Ridgeline use different locks than the cars.
If you want shorter locks, and don't mind the appearance of an open ended wheel lock, get a set for a Civic Hybrid.
Anyone have the part number for the discontinued short locks? Thanks!
Update: N/M, found them here (#08W42-SCV-101): http://www.handa-accessories.com/s2000-04ext.html
