HELP!need advice on blitz 01 rims fitment on s2000
Old 01-22-2009 | 10:27 AM
swaps2000's Avatar
Default HELP!need advice on blitz 01 rims fitment on s2000
i think there a +42 in the back and a + 36 in the front
i wondering if they will fit and what tire i should put on them
thanks!!!
Old 01-22-2009 | 10:42 AM
swaps2000's Avatar
bump
Old 01-22-2009 | 05:39 PM
swaps2000's Avatar
bump
Old 01-22-2009 | 08:22 PM
EBinVA's Avatar
You'll need to at the very least roll your fenders big time and run massive maounts of negative camber. You may have to stretch tire as well. Failing that, you'll need overfenders or pulled fenders.
Those offsets are a bit low for fitting those widths on an S2000 comortably.
Old 01-23-2009 | 11:53 AM
CLEAN2K4's Avatar
def gonna need to do some work as ebinva stated.im running the same wheel sizes but with +50 on all four wheels an the rears rub without rolling fenders..i can say that with your offsets id just stay away from that set of wheels.you can MAKE almost anything work tho.if you choose to run the set id stretch the tires like 215-225 front an 235-245 rear bigger tire more camber less tire less camber
official_s2k
01-26-2014 10:58 AM
pawel1026
01-21-2014 09:34 AM
Eviljokersti
01-17-2013 11:02 AM
GerardoCastillo
05-27-2012 12:27 AM
aznvietboy725
02-13-2012 02:02 PM
