help on sizes!!!!!!!!!!
I was looking to run 18 inch rims on the front with a width 8 inches and an offset of 55. My tires would be 225/40-18. And on the rear also running 18 inch rims with a width of 10 inches at an offset of 74. The rear tires would be 285/30-18. Also i have the kg/mm springs which drop the car 35mm. Does anyone think that it would rub or if i would encounter any other sort of problems.
thanks
thanks
I have heard of people running 285/30R18 on the rear but it is well outside our recommendation. On top of the fact that the 285 on the rear will really make the car push in corners. I think you would be better with the 265/35R18 on the rear. Hopefully someone will comment that has the 285/30 R18 in the rear.
Jim
Jim
