Help with offsets (Kosei K1)
I read the offsets are not ideal.
Front 17x7 +50
Rear 17x8 +45
Are these OK or should I keep looking? I have stock hight, what tires will fit with these with no rubbing?
Thanks for any help
Front 17x7 +50
Rear 17x8 +45
Thanks for any help
Originally Posted by SpeedxRacer,Feb 20 2006, 01:42 PM
yes they will work, the rears might rub but you will be fine if you roll you rear fenders.
Tirerack says "will fit" S2000.
You should be OK if you use the tire sizes that Tirerack recommends with those wheels. Those offsets aren't too bad. If you are adventurous you can try the OEM AP2 tire sizes.
Can someone explain the "problem" with ap2 tire size? Why might this be an adventure?
