Has anyone put a Victoracer 245/45/16 on a 7" wide rim?
Old 04-23-2002 | 09:12 PM
TypeSH's Avatar
Default Has anyone put a Victoracer 245/45/16 on a 7" wide rim?
I know it is not optimal, just wondering if it is doable.
Old 04-23-2002 | 10:23 PM
j2k's Avatar
j2k
I've never done it personally... but I'd say you could do it.
-jason keeney
Old 04-24-2002 | 11:48 AM
s2k2fast4me's Avatar
I've put a 245/45 17 on a 7" rim and seen the 255/40 17 on a 7" rim.
Old 04-24-2002 | 11:51 AM
krazik's Avatar
Administrator
I put 275/45 hooisers on the rear stock 7.5" rims.
You shouldn't have a problem
Old 04-24-2002 | 12:05 PM
Jim@tirerack's Avatar
Former Sponsor
The problem is are you maximizing the tire. If you have to pull the tire in to seat on the wheel you are also pulling the outside of the tire off the ground to do it. On top of the fact that the sidewall is pulled in. There is always an optimal wheel size for a given tire. Can you do it? Probably. Would I recommend it? No
I hope this helps.
Jim
Old 04-24-2002 | 01:01 PM
TypeSH's Avatar
Well do you think a 225/50/16 would give more contact patch than a 245/45/16 on a 7" wide wheel? I figured they would be about the same but was favoring the 245 because of the gearing advantage since it is .3" shorter.
Old 04-24-2002 | 02:58 PM
Former Sponsor
It would depend on the individual tire. The tire mfg. recommend a minimum rim width for a reason. To put on a wider tire and the outside shoulder is not on the ground doesn't make any sense. As far as the gearing goes, yes it is a little shorter but it is also a liitle heavier.
I would not recommend it.
Jim
Old 04-26-2002 | 01:49 PM
Russ's Avatar
The recommended measured rim width of the former tire is usually 7-inches while the latter is 8-inches so by placing the 245 on a 7-inch wheel, you're reducing the contact patch by 10mm, so it would still have a wider patch that the 225.
unlewser
01-29-2011 12:55 PM
p0staboy
12-13-2010 05:59 PM
t.vo408
05-10-2006 05:57 PM
Aznous
12-20-2005 02:41 AM
tunerjetta29
10-15-2005 12:20 PM
