Fitting 17x9 TE37s to get 255/40/17 square
Old 08-18-2016 | 10:11 AM
limenuke's Avatar
Default Fitting 17x9 TE37s to get 255/40/17 square
If anyone has any advice for fitting TE37s specifically - I'd like to know if I need new fenders or if I can just roll them a bit? There's a few sets on the market with +22mm offset, which is a bit nuts to fit. I don't know if there's anything that's like, +60mm..
Old 08-18-2016 | 10:54 AM
S_DosMil's Avatar
Find the highest offset +50 range and roll fenders and relocate tabs. Not sure if that offset exists but that's your best bet.
Old 08-18-2016 | 10:57 AM
Manga_Spawn's Avatar
Site Moderator
17x9 +22 would need aftermarket fenders. I have seen sets with higher offsets but they have all been used sets so you may have to hunt. This topic is in this same section.
https://www.s2ki.com/s2000/topic/115...t__p__24001637
Old 08-18-2016 | 12:39 PM
Breyeun's Avatar
If you don't mind flat face, best route is S2K specific sizing or 17x9+45 TE37SL is another option. You should only need a roll and relocated tab to fit that on a 255. I believe there's actually a set on the Wheels marketplace right now.
Old 09-10-2016 | 06:18 AM
vanDiemen's Avatar
That set is actually mine. You need 17x9 +63 rear and 17x7.5 +48 front. That's an even +1 increase on a stock s2000 allowing you to go to 225/255 with no fender mod. I had them on stock susp then kwv3s at the correct height (not slammed) with no problems.
pappi16
12-20-2012 08:03 AM
Corey Maurer
09-13-2010 05:39 PM
ap1 love
11-14-2009 07:38 AM
CarBoN
09-09-2009 07:06 PM
revoluzion9k
09-19-2008 06:27 PM
