Fitting 17x9.5 +55 Non Staggered with 275s
How much of a major pain in my rear end is this going to be. I know I can fit it on the rears. Im worried about the front but I believe it SHOULD fit. I am rolled on four corners and on coils. Thanks.
Should be able to fit. I'll be doing something similar, except running 17x10 +62 in the front.
Key issue will be inside clearance to the control arm at full lock. Your setup will fit without rubbing. For reference 17x10 +52 slightly rubs, but will fit with a 3mm spacer. Your 17x9.5 +55 will have 1 mm extra inner clearance in comparison to the +52 wheel w/3mm spacer.
As for pinching the tire. NT01 spec's their 275 using an 'approved wheel width' range from 9 to 11"
