Is this fitment possible?
Old 05-18-2009 | 01:27 AM
Vik2000's Avatar
Thumbs up Is this fitment possible?
17x8 +25 front and rear.
Also is it harder to fit a 17x10 +35 in rear or 17x8 +25?
Old 05-18-2009 | 03:17 AM
Dressed2Kill's Avatar
A 17x10 +35 will stick out 15mm more than a 17x8 +25. You biggest issue is going to be fitting the 17x8 +25 up front without aftermarket wide fenders.
Old 05-18-2009 | 06:31 AM
S2K 4 ME's Avatar
Whatever your looking at, I would pass on them. It'll take alot of work to get any of those work, unless you have a W/B.
Old 05-18-2009 | 09:50 AM
Vik2000's Avatar
I think Wider front fender and rear overfender would make it easier right?
Old 05-18-2009 | 11:17 AM
S2K 4 ME's Avatar
Easier, but I'm still not sure they would [rovide enough clearence for a +25.
I'm running 18x10 +68 in the rear, that means your gonna stick out 33mm more than I am right now, thats a hell of alot, even with overfenders.
Old 05-18-2009 | 12:54 PM
s2k dre's Avatar
The rear would fit with a 235 tire! The front has been done on stock fenders. But it depends what ur willing to do to make them fit.
Old 05-18-2009 | 01:40 PM
antbo's Avatar
^^im with him. theres no honest answer. its all up to you. they can give advice. but are you willing to go through with fender mods and some additional camber
Old 05-18-2009 | 08:05 PM
Vik2000's Avatar
so it's actually easier to fit in front than in rear??
Old 05-19-2009 | 06:40 AM
With the ASM/J's racing rear fenders most people are running a 9" 22 offset. That stick out the same as a 10" 35 offset so you should be "good to go" with the ASM or J's rear flairs. To fit a 8" 25 offset in the front I would look at the ASM(+25mm), Spoon(+25mm), or Gotuning(+30mm) wide fenders.
Duckman
05-06-2014 07:52 AM
darksparkz
02-16-2011 07:25 PM
dan_uk
12-15-2009 09:44 PM
HankookS2K
08-21-2009 08:18 AM
b20teg
07-15-2008 07:36 AM
