fitment & offset question
I'm planning on running 17x8 +35 215/45/17, 17x9.5 +41 245/40/17....anyone running that setup?
right now i'm lowered on tein springs, no fender roll. will i have any fitment issues with those offsets? I really want to go with 255 in the back but if that requires a fender pull, i would stick with 245's.
Thxs!
Thxs!
Whoops didn't see that you were the op
If the ones you posted about were a 9" wide rim, they would be at +35 offset which is 10-15mm more aggressive than the ones you have now which is a pretty big difference.
that's weird, you must drive on some nice roads... if you have 18x9 +45-50 in the rear and you go through a big dip in the road you should rub a little bit (unless you actually have 18x9 +60 or something close to that).... But regardless the wheels you are looking at definitely are quite a bit more aggressive
fyi I had some 18x9.5 +52 in the rear with 255s and I rubbed with some camber... although I was lowered about 1.5-2"
haha no nice roads....i used to rub a little on old tires Kumho's, same size but it wasnt all that bad so i never did a fender roll. After i replaced to bridegstones, it doesnt even rub at all anymore lol....
but going back to 17" rims so was wondering on the offsets cause i know they arent that s2k friendly....
sofresh&soclean
04-03-2010 04:11 PM
