Fitment help and questions
Hey guys,
I've been doing a lot of research browsing the forums and googling and I THINK I have in mind what I want and whether or not it fits. Want to run it by some of you experts in here.
I'm planning on ordering some Work Emotions ZR10 and I want 17x8 +35 in the front and 17x9 +32 rear (only offset for 9inch width other than +17). Tire wise I'm thinking Advan Fleva 225 front and 255 rear
Ideally I would like to avoid any fender modifications if possible. I plan to also do BBK (TL type S brembo) and lowering on coils (not slammed, maybe about 20mm or whatever to get the fitment to work).
Anyone here who has experience can chime in if this set up should be ok? Mainly clearing BBK and, if possible, no fender modifications are my two main criteria.
Thank you!
Thank you!
Flush fitment and no fender mods at the same time is impossible. Pick neither or pick both.
Go look at your stock fenders. They have an inner lip that's directed inwards. If you want to keep that your wheels will need to be inside the wheel well by at least that amount plus some extra for clearance.
Thank you for your input
If you want to keep the inside lip, the setup you are suggesting is waaaaaay to aggressive
I am running 17x9 +40 with a 255 and had to roll my fenders A LOT to make it fit, your setup is even more aggressive than that in the rear, in the front a bit less so, but still way too much
Received 1,315 Likes
17x9 +32 is not going to fit with a sensible amount of camber, unless you buy fender flares or do something else drastic. A roll and tab relocate is not enough to fit this.
The car came with 17x8.5 +58 or something. You're proposing using a size which moves the face of the wheel 1.27" outboard.
17x8 +35 will fit up front, with a flat lip roll and cutting off most of the fender tabs. You will still need to be extremely careful when you turn/go up inclines/go down declines to avoid turning your fenders into bacon.
Trying not to be rude...you said you researched this fitment? Would that statement hold up in court?
Given the sizes you say are available, these wheels are just a bad option for an S2000.
I'm starting to consider other options, similar styles like Volk CE28s since those seem to be more S2k friendly. I just need to make sure they'll clear BBKs
The following 2 users liked this post by B serious:
jnewtons2k (Today),
Streetfury (07-03-2024)
