F225/45/17 R245/40/17 8inch AA
Old 08-20-2016 | 04:00 AM
s2kpotenxixe's Avatar
Default F225/45/17 R245/40/17 8inch AA
Probably talked thousand times.
Is this setup ok in 8 inch wheels?
I have calculated tire diameter with Rob Robinette's android program (carcalculator) and rear wheel looks smaller.
But due to a straight tire I guess that the tire will be more stretch then... bigger?
245 40 17
Tire diameter : 24,71
Section width : 9.64
225 45 17
Tire diameter : 24.97
Section width : 8.85
What do you think?
Old 08-20-2016 | 04:54 AM
1nate7's Avatar
Run a 215/45 front if you want the diameter to match.
Old 08-20-2016 | 09:06 AM
Dreaming_S2k's Avatar
^This. Either 215/45 F & 245/40 R, or 225/45 & 255/40 if you want the OD to be the same.
Old 08-20-2016 | 09:51 PM
Thanks for answering. Well probably 255 is too much for a 8inch tire so... I will have to choose 245 for rear? Rims are impreza sti's and I guess they are not exact 8 inch but 8.25
Kind regards
Old 08-20-2016 | 10:46 PM
S_DosMil's Avatar
If you have. Square setup why not just run 245/40s all the way around?
Old 08-21-2016 | 04:03 AM
Well you are right. But the tires I would like to buy go from 235 to 255. Probably I can look for other 245 brand.
245/40/17 all around?
Old 08-21-2016 | 08:45 AM
S_DosMil's Avatar
What tires are you looking at? 255 is to much for an 8" that's a personal thought. 245/40 looks and fits pretty damn good.
Old 08-21-2016 | 12:55 PM
Echoing the other opinions here, I think 245/40 all around is the best way to go.
Which tires are you looking at?
Old 08-21-2016 | 11:11 PM
Nankan ns2r 120 compound.
This wheels go from 225 - 235 to 255.
Now am running a allarround 225 set and I feel that 225 is too narrow for rear. With the puddy4.77 corner acceleration is difficult in second gear...
Old 08-22-2016 | 07:02 AM
Yeah, I'd definitely look at a different tire honestly.
Any of the usual suspects would work well. RS3, AD08R, Z2 SS, etc...
