Extended Stud Question (H&R)
Old 03-22-2010 | 10:03 AM
synth19's Avatar
Default Extended Stud Question (H&R)
Hi, I have a set of 5mm rear spacers from H&R. I will be installing a BBK this weekend so I was going to install the extended studs since everything will be out anyways. My question is, eventually I will need a 10mm spacer in the rear. These definitely will require the extended studs. Is the length of the extended studs for the 10mm kit the same that come with the 5mm kit? Thanks!
Old 03-24-2010 | 01:27 AM
s2k dre's Avatar
From h&r they are different lenghts.
bayareas2k
05-06-2010 09:13 AM
fishs2000
02-18-2010 05:24 PM
velocityracer
08-06-2008 05:02 PM
SojuSoulja
11-02-2007 04:48 PM
303WIN
09-27-2007 11:12 PM
