enkie rpf1 17 will spoon caliper fit
Old 05-14-2008 | 03:44 PM
timothys2k's Avatar
Default enkie rpf1 17 will spoon caliper fit
as title stated i have enkie rpf1 17s +48 will the spoon caliper fit if not how much of a spacer is needed
Old 05-15-2008 | 06:27 AM
Jim@tirerack's Avatar
Former Sponsor
If you send me a brake drawing/template I would be able to tell for sure.
Old 05-15-2008 | 07:42 AM
Sinji's Avatar
there was a guy stating on here that his 17x9 +45 did not clear the spoon. i would suggest running a lower offset like a +35 but just going with a narrower wheel.
Old 05-15-2008 | 02:37 PM
Chris_Lum's Avatar
What rim width?
My 17x8 +45 just barely clears my Greddy calipers with no spacers. I can't imagine the spoons are much bigger (or bigger at all). So even if the spoons are slightly bigger, you could probably get away with a small spacer. The 17x9 +45 will definitely not clear.
Old 05-16-2008 | 03:42 PM
timothys2k's Avatar
my rpf1 ar 17x7 1/2 if that makes a difference +48 offset if that makes a difference
Old 05-16-2008 | 04:16 PM
Sinji's Avatar
you have to remember that offsets are not based on wheel width. its measured from the center of the wheel outwards. so the +48 will not work unless you put in a spacer
Old 05-16-2008 | 04:44 PM
1nate7's Avatar
I think it will probably clear or worse case need only a small spacer. RPF1's have drastically different faces. Like has been stated, a 8" +45 (curved) has way more brake clearance than a 9" +45 (flat) because of the spoke difference. I believe the 7.5" +48 has the curved spokes so there is a lot of room, but I can't confirm that they will 100% clear.
Old 05-18-2008 | 07:30 PM
Integra21's Avatar
^correct, the concave 17x9 +45 RPF1 will not clear BBK's without serious spacer action
veilsideLGD
05-14-2016 08:30 AM
giorgistsam
09-25-2012 02:02 PM
Oyagi
08-30-2012 09:51 PM
MB
08-26-2010 03:49 PM
Bebelmm
20
12-15-2009 09:20 AM
