Enkei RPF1 with +45 offset, rub or no rub
Enkei RPF1s 17x9 +45, all around. 215 tires in the front, 255 tires in the back. Lowered on Espelirs
Is there any fender modifications needed for this setup? really dont want to mess with the fenders.
I have these but I am 255 square all around so I don't know about the front. OEM suspension with Espelirs. I can tell you that in the rear I was rolled and cleared, but after trimming the bumper it still rubbed a bit until it wore that spot off the bumper. Without a roll I don't think it would fit.
Forgetting the fact that a 215 on a 9" is really over stretched and will look pretty goofy as well as unsafe, you will still have clearance problems up there if you are lowered at all. I realize a 8" +45 has the convex face, but that will actually accommodate a 215 properly and not have to roll with appropriate camber. The rear will clear without a roll if you’re running 245 and a liberal amount of camber like -2.5. the 8/9 +45 is a stock fitment without rolling fenders as long as you stick to stock tire sizes and run at least UK spec camber alignment, but another half a degree all around is best.
Site Moderator
Roll all the fenders. Only option for these to fit. It is pointless to run a 9 inch wide wheel with a 215 when you could just but a 7 or 8 inch wide wheel and run that tire and have less clearance issues.
Thanks guys, havent considered the tire width. Think im going to hold off on the RPF1s then cause I need to get new tires, roll the fenders to do it properly. my tires are still full of life so when those go Ill make the swap
