Enkei RFP1 fitment
#24
You can probably go with a little less camber.
In those photos, I was running Falken RT-615s 215/235. Their tires run a little wider than others so I am not losing much if any tread width between from other brands.
#25
Originally Posted by IIGQ4U,Nov 5 2007, 06:08 PM
I hate to whore my pics around but in this case, it is relevant.
would i be fine to get those rims? im not as low as you are. the rims in the pick are the 17x8 and 17x9 right?
also, where did you get those center caps?
#26
The offsets are not ideal for the S2000 but if you are willing to make them work, you can.
I won't bear the responsibility of advising you on whether or not to purchase a particular set of wheels but I will say that you can make them work fairly easily.
Regarding the centercaps, I designed them and had them machined.
#27
i really want a set of volks... but these wheels are so much cheaper and also really light.
#29
Originally Posted by Aze85,Nov 5 2007, 08:35 PM
i have a comfortable 2 finger (index and middle fingers) on both the front and rear. i am running -2.5 camber in the rear, but i cant remember my front. its the uk spec alignment.
#30
Originally Posted by Chris_Lum,Nov 5 2007, 11:36 PM
i dont have problems of the fronts eating up my fenders on driveways either...i run 215 front and 255 rears on RT615 tires.
