does 255/35-18 require fender mod?
Old 01-06-2010, 12:47 PM
aviator's Avatar
Default does 255/35-18 require fender mod?
i tried to select the optional tire choice on Tire Rack (selected through the S2Ki Upgrade Garage link). for the rear, 255/35-18, Tire Rack had the following warning at the top:
Rear: Aggressive fitment. Will require fender modification for proper clearance.
i will be running +55. based on the 'sticky', i shouldn't need any fender mod. is Tire Rack's message some form of just legal disclaimer? in reality, it should work?
thanks.
Old 01-06-2010, 01:43 PM
Tripleblackap1's Avatar
No," I have a 8.5 +55 wheel with a 255 35 bfg kdw2 and it just clears my stock fender. I am running UK camber specs though, which are -1 front and -2 rear to do this.
Old 01-06-2010, 01:49 PM
Former Sponsor
Jim@tirerack's Avatar
With the lower offset wheels the 255 can rub. I have had a few cars with the 17X9 ET 55 hit some times. A lot depends on the size of the specific tire and the camber that the car is running.
If I can help let me know.
Old 01-06-2010, 02:06 PM
aviator's Avatar
thanks. i just talked to jim at Tire Rack. he clarified that choosing 8.5" width at +53 would clear. (i was thinking 9.5" then 9.0" for the rear; unnecessary)
Old 01-06-2010, 02:07 PM
aviator's Avatar
[QUOTE=Jim@tirerack,Jan 6 2010, 02:49 PM] With the lower offset wheels the 255 can rub.
Old 01-06-2010, 04:01 PM
Vanishing Point's Avatar
I have the 255/35-18 on 9" rears with +56 offset wheels and have no issues.
Old 01-06-2010, 04:24 PM
aviator's Avatar
thanks steven. i will be getting 255/35 on 18x8.5 +53.
Old 01-06-2010, 04:56 PM
Aviator, what size fronts are you going with? I would try to keep the same ratio of stagger as stock configuration. Best of luck with your choice of HRE's!
Old 01-06-2010, 06:56 PM
GrandMasterKhan's Avatar
i ran +52 volks in the rear and i needed a ROLL and tab relocation when running 255/35/18 BFG gforce sports.
My car was lowered with aggressive 2.5 degrees of camber.
Old 01-06-2010, 07:02 PM
aviator's Avatar
steven, here are the specs:
front: 18x7.5, +55; 225/40
rear: 18x8.5, +53; 255/35
do these make sense?
thanks.
henry.
Quick Reply: does 255/35-18 require fender mod?
