Do driveshaft spacers affect wheel offsets?
Tried searching but couldn't find a positive answer. Do 10mm driveshaft spacers affect your wheel offset? Any input would be helpful. thanks
I wouldn't think so since your offset is determined by the hub and suspension, and the axle spacers don't re-position the hub since those are held by the control arms that have a "fixed" postion. The driveshaft spacers if I understand it correctly, correct the axis of the drive shafts that change from being pulled downward by a lowered vehicle. The spacers aren't changing the track but correcting the axle's travel range.
