Different tire wear on left and right ????
My S2000 tracks beautifully and seems to be handlng very well. The only handling oddity is that the front end is a little squirrely under heavy braking (which I do rarely).
Perhaps Jim can tell me why my right rear tire is much more worn than my left rear (the wear is pretty even from edge to edge), while might right front tire shows a lot of wear on the inside edge, but my left front is wearing uniformly across the tread.
What are the factory alignment specs front and rear, and what are the "better" ones that Jim recommends ?
What should a really good alignment job cost ?
petouche, Those sound like questions for the dealer. The only thing I recommend is to run lower toe in to increase tread life of the tires. You would want to be within Honda spec for the alignment. The toe in would be 4mm rear.
Jim
Jim
