Did i get the wrong size?
Old 12-24-2006, 01:04 PM
S2Kabob's Avatar
Default Did i get the wrong size?
FRONT are stock..
Rears just got swapped out with 245/40/17 ... long story short.. nowhere is open xmass eve . only placed has the fuzion 245/40's in stock .. nothing else. no choice.. so i opted for it..
so.. am i running the right size..
FRONT is stock and Rear is 245/40/17 fuzionz.. i hear they are a ggood bang for the buck.. figured i would try them then get my hands on something better when the time comes about..
thank!! .. btw. i havent had a chance to mount the wheels on..
Old 12-24-2006, 03:24 PM
CRDMS1's Avatar
The information you need is in the sticky at the top of this forum...Section 4.1...suggest you check it out:
Wheel Fitment Guide
If all else fails...tirerack.com will tell you what the stock sizes are:
Tirerack S2000 AP2
Old 12-24-2006, 03:43 PM
S2Kabob's Avatar
just out of curiosity.. do you have the answer to my question or you simply dont know and your point me to the right direction..
Old 12-24-2006, 03:47 PM
S2K 4 ME's Avatar
I have Fuzion Zri 40 series all the way around...........technically the rears should be 35's but it wont hurt you any.
Old 12-24-2006, 04:49 PM
S2Kabob's Avatar
i do plan on ripping through them as quick as i can since i had no other choice at the momment..
i still havent had a chance to put them on .. prob gonna have a more aggresss stance? nose down type thing if any??
yarou's Avatar
shouldnt the rears be 245/45? not 35?
Old 12-24-2006, 06:37 PM
TR-S2K's Avatar
Originally Posted by S2Kabob,Dec 24 2006, 02:04 PM
FRONT is stock and Rear is 245/40/17 ...
You got the correct size for the rear with stock front.
Old 12-24-2006, 07:16 PM
silentdancer's Avatar
on a 16 inch rim yes.
on a 17 inch rim, 40 series
on 18 inch rim 35 series
Old 12-24-2006, 07:53 PM
DerrS2K's Avatar
Those tire with the oem front tires are going to give you massive oversteer. You really shouldn't mix and match tire brands/models. You have the correct size but your handling will be much different. Don't push it like you might have before.
Old 12-24-2006, 09:55 PM
BSeriouS's Avatar
245/45-16 Is the correct tire size for 16" wheels.
245/40-17 Is the correct tire size for 17" wheels.
245/35-18 Is the correct tire size for 18" wheels.
Quick Reply: Did i get the wrong size?
