Could we get a Sticky?
I'm sure this info is out there...but maybe we could make a sticky out of it and make it very easy...
can we just get the correct offsets (or offset "ranges" that would be acceptable) for different rim sizes.
Fronts, and Rears...
16x7
16x7.5
16x8
16x8.5
16x9
16x9.5
16x10
17x7
17x7.5
17x8
17x8.5
17x9
17x9.5
17x10
18x7
18x7.5
18x8
18x8.5
18.9
18x9.5
18x10
Now I think all that matters when you talk about offsets is the width? But I wasn't sure so I put the 16's-18's (only sizes I think should go on an S)...19's ehh bling when it aint a bling car
So ya, if we could sticky the possible offsets of these widths, that would be great.
Example on a 2g Eclipse to run a 8" wide rim you need between 38-42mm offset 40 being optimal... so if we said 17x8" is 38-42...instead of just 40, in order to reduce the number of people asking is 38 OK etc, etc
If the rim width will rub, regardless of offset, or if rolling fenders is necessary...right that in as well...so say if 10 or 10.5" just wont work, write 10.5"+ will rub regardless, or 10" must roll fenders, will rub, offset = XXmm
Ok...now all you smart knowledgable guys, you could just throw all the info in here if you want, then we can consolidate it into a single thread later.
Also, please don't say only say what offset worked for you...we need the correct range of offsets that will work for anybody.
16x7
16x7.5
16x8
16x8.5
16x9
16x9.5
16x10
17x7
17x7.5
17x8
17x8.5
17x9
17x9.5
17x10
18x7
18x7.5
18x8
18x8.5
18.9
18x9.5
18x10
true ya...I thought about that...maybe the more experienced people could also add that...but then of course there are also different tire sizes, etc, etc...and not all rims are made the same (some might be a little bit off)...but at least having the offsets would be a start.
I know that my car is dropped with KG/MM's I don't know how wide I could go with out rubbing...but maybe that can be answered...
If you have the right offset though, then rubbing shouldn't be a problem because the wheel is tucked behind the fender...but then you could also only go so wide before it starts to stick out.
Look what I found...ooooo
https://www.s2ki.com/forums/index.php?showt...=wheel++offsets
HONDA S2000 CONVERTBLE 2 DOOR 2000-2003
OEM
F 16X6.5.....+55mm.....70.7mm hub bore
R 16X7.5.....+65mm.....64.1mm hub bore
5-114.3 BOLT PATTERN 12X1.5 LUG NUT w/19MM HEAD
WIDTH....................OFFSET ..........................WIDTH OF TIRE
FRONT
7.0........................+40/+45.............................205/215/225
7.5........................+40/+55.............................205/215/225
8.0........................+40/+55.............................205/215/225
REAR ONLY**DIFFERENT HUB BORES FROM FRONT TO REAR***
8.0........................+45/+55.............................245/255
8.5........................+50/+65.............................245/255/265
9.0........................+55/+65.............................255/265
9.5........................+60/+65.............................255/265
10.0......................+73/+75.............................275/285
COMMENTS:
+40MM OFFSET WITH AN 8-INCH WHEEL IS AT THE EDGE OF
THE FENDER WITH THE TIRE A 1/4 INCH OUTSIDE FENDER.
LOWERED VEHICLES MUST USE HIGHEST OFFSETS POSSIBLE.
POPULAR FITMENT:
17X7.5 +45MM OFFSET 215/45R17 FRONT
17X8.0 +50MM OFFSET 245/40R17 REAR
Now...we could just write this out in a new thread and sticky it...
OEM
FRONT
COMMENTS:
POPULAR FITMENT:
