Correct offset for 17" TE37s?
Old 01-12-2006 | 11:58 AM
StinkyTofu's Avatar
I don't think everyone is. Not all 245 tires are the exact same width and remember, all it takes is an extra mm of rubber to cause a headache of rubbing. Go with an aggressive rear camber and you should be ok. Then just flip flop the tires when the uneven wear gets pretty visible.
Old 01-12-2006 | 04:52 PM
04RioS2k's Avatar
yes with the right tires you shouldn't have a problem, so try to get something that is a little smaller in width than the re050....
Old 01-12-2006 | 05:54 PM
i_heart_my_DB8's Avatar
Aren't the RE050's pretty good tires? I don't want to have to put crappy tires on just because the wheels are the incorrect offset.
Argh. I don't want CE's.... any other good tires available in OE AP2 sizes that have a narrower width than the RE050's?
Old 01-12-2006 | 11:46 PM
ASMspec's Avatar
If your going with a BBK sometime in the future these high offsets wont work. For a TE37 wheel with an Endless, Project Mu, Winmax, Js Racing type caliper you will have to run in the low to mid +30s offsets and even then you may still need a spacer.
If your are keeping your stock calipers then +48 and +50 is whats offered..Even then the rear is to low for a 255-265 rear tire and the front will work fine with a 215/45 tire.
Old 01-13-2006 | 01:03 AM
WyattH's Avatar
Yeah, I needed a 15mm spacer for my 17x7.5 +48 to clear a Stoptech caliper. And then the wheel was past the fender visibly.
Old 01-13-2006 | 09:20 AM
I don't think I'm planning on running a BBK anytime soon. I'm having a hard time justifying the cash for wheels as it is
SuperSaiyan
07-01-2014 08:33 AM
olapua
07-26-2010 09:04 PM
LdoubleE
03-31-2006 08:44 PM
mdm
03-21-2003 06:55 PM
GDPzS2000
01-13-2002 12:49 PM
