Can these Rg1's fit?
hi all, question for the wheel gurus out there.
i have come across a 2nd hand set of rg1's, the wheel size are 17x9 +30, is it possible to make these fit the s on all 4 corners?
any comments appreciated, thanks
It is possible, but if you dont know what you are doing, it is not recommended. These wheels would require fairly extensive fender rolling/pulling, lots of camber, and very narrow tires.
ye i was prepared to fender roll, some camber and use narrow tires but not fender pull
its rare to come across rg1s with the correct specs now that they are discontinued
thanks for the comments, I'll probably pass at this time and search on
LordSovereign
10-16-2014 10:37 AM
