Can I run these offsets?
Originally Posted by skafia,Apr 30 2005, 06:34 PM
I might pick up a set of 18" Volk SE37's and I'm wondering if I can run these offsets on my S2000:
Front: 18x7.5 +42
Rear: 18x8.5 +45
Thanks.
Front: 18x7.5 +42
Rear: 18x8.5 +45
Thanks.
Bassed on what I have on my AP2 and the offset calculator.
Mine
8+49 225/45 +.25deg more camber over stock
9+49 265/40 +.20deg more camber over stock rear fenders rolled 1.2"drop all the way around
going to your setup
you would be able to run a tire with a section width of 8.849" in the front
and a tire with a section width of 10.785 in the rear (assuming you roll your rear fenders
which puts you in the
225/40 front and a 255/45 in the rear range for an 18" rime and avaliable tires for an 18
Mine
going to your setup
