can i mix and match tires?
i currently have 2 s02s on the fronts with about 95% tread left, and S02s on the rear with almost no tread left. my question is , would it be ok to leave the s02s on the front and put something like s03s on the rear, or maybe even the yokohama AVS ES 100s on the rear? how do these tires compare ? and would they be ok to mix? the reason im thinking of changing is that the so3s and yokohamas rate a little better in wet conditions and in tread life. i occassionally take a fun aggressive drive, but the fact that the s02s slightly outperform in dry conditions isnt that important to me.
EDIT:: i also see that the yokohama AVS dB S2s look very comperable also.
thanks in advance.
-tony
thanks in advance.
-tony
