Can I drop it
Can I drop it
I'm currently running volks 18X7.5 +48 / 18X8.5 +50 on 225/40/18 front tires and 255/35/18 rear tires. I know I can only drop the car a minute amount before I rub however, mod day is coming up and there will be a fender roller.
If I do not roll my fenders, can I even drop the car? If so how much -- I was thinking the RS*R springs that lower the car 20mm front and 30mm rear.
If I roll my fenders, how much could I drop her?
Thanks, I suck at knowing offsets and how they actually play in how much you can drop cars.
you should be fine with a 1-1.5 inch drop, rolled rear fenders, and some negative camber (UK spec alignment should be ok) - the offsets don't seem too bad... I would have gone with 215/245 tires.
215/245 is your best option. or else add a bit more camber. more than the uk spec. im running those wheel spec on the 17s and they rub on the my bracket and bumper eventhough i rolled my fenders. right now i only rub on the bracket after i shave a bit on the bumper. so relocating the bracket is the last solution tot his porblem. but if i had 215/245 i wont go this far on the bumper and bracket. by the way, im running -1.5F and -3R on camber. and drop around 1.25-1.5
BerlinaBlackS2kguy
03-15-2007 05:14 PM
