can 205 fit on ap1 rear rim?
Old 11-27-2007 | 04:50 PM
jeggy's Avatar
Default can 205 fit on ap1 rear rim?
just like the tittle, can a 205 tire fit onto the stock ap1 rear rim?
they counter guy at discount tire said they will.
i imagine with a bit of stretching?
how bad is it (i HATE stretched tires)?
Old 11-27-2007 | 06:27 PM
Carnine's Avatar
do you know what stock tire size is?
Old 11-27-2007 | 07:28 PM
Flite's Avatar
It will be seriously stretched.
Why would you want to do this?
Old 11-27-2007 | 11:07 PM
silentdancer's Avatar
wow, dont ever go to that tire shop again. what is their reason for a 205 tire in the rear?
if you arent running the original s02's then you should be running 245/45 in the rear
Old 11-27-2007 | 11:43 PM
Stephenopoly's Avatar
uuhhhh i hope your are kidding. The tire will be retardly stretched and you are going to oversteer everywhere... have fun!
Old 11-28-2007 | 04:36 AM
Carnine's Avatar
so then why do most ap1 as autocross set ups use 245 front and rear if they are gonna oversteer like crazy?
Old 11-28-2007 | 10:34 AM
JustinsanE's Avatar
what does that have to do with putting a 205 tire on the rear carnine?
Old 11-28-2007 | 09:13 PM
s2kologist's Avatar
Old 11-29-2007 | 01:09 AM
yeah cause im sure the point of putting 205's on the rear is to handle better
Old 11-29-2007 | 07:34 AM
Sinji's Avatar
they use bigger tires for the front for better turn in grip. and as you know the 245 have a bigger contact patch. plus some tracks require for the driver to better swing the car around while still maintaining a higher grip that the contact patch can provide. 205 on the rear is just something retarded to do.
