Buzz noise after tire installation
Old 05-28-2008, 06:39 AM
Defjux's Avatar
Default Buzz noise after tire installation
Had 17" wheels with brand new tires mounted on my car (AP1) this weekend. Since then, I hear a sort of buzz / drone coming from the front every time I make a turn. The sound seems more noticeable when turning to the right., though. I am riding stock height, so it is not a rubbing issue.
I know the tires need to break in, is this where this is noise could come from? Or should I get an alignment check?
Old 05-28-2008, 07:58 AM
mrbacardi's Avatar
i had a similar issue on another vehicle. Buying wheel spacers for the front wheels solved the problem.
Old 05-28-2008, 08:13 AM
gotswap's Avatar
If it has been a while you might want to check out your alignment, you could be scrubbing. Could also be the tires but I would for sure get an alignment.
Old 05-28-2008, 08:30 AM
Defjux's Avatar
Forgot to mention the wheels are 17" Work Emotion Forged, offsets are +40 for the front and +59 for the rear. Tires are Sumitomo HTR-Z III, 215/255.
Old 05-28-2008, 08:37 AM
Defjux's Avatar
I just looked at the oem wheels I removed, seems the front left has excessive inner rib wear. Guess means the camber is messed up...
Old 05-28-2008, 09:19 AM
gotswap's Avatar
I would prolly point at toe or caster, especially since you get the nois while turning.
johngamez
12-30-2012 01:59 PM
StockSH
08-08-2012 06:51 AM
FISH22
08-22-2011 06:54 AM
BFAmazon35
09-03-2009 03:03 AM
Max_Spd
06-10-2009 07:45 AM
Quick Reply: Buzz noise after tire installation
