buddy club p1 racing II wheels
For the buddy club p1 Racing II wheels, what be the lowest offset that would fit our cars? What offset and width for 18s and what offset and width for 17s. I am most likely not going to drop the car, so would 17s look better without a drop? Thanks!
Tire Rack does not sell Buddy Club. You may contact someone who does. And their offsets for the s2000 are not ideal offsets. 17" or 18". But if you do wish to run their wheels. You can sacrifice it by run smaller tires front and back. So you won't run into rubbing issues. Recommended offsets are 48+
Iwas looking to get the same wheels at one point. Here is a spec sheet. Hope it helps:
http://www.wheelspecs.com/specs/wheelmodel...ls/465&sort=pcd
ok, here's a set up you can run
18x7.5 +48 215x40x18
18x8.5 +48 245x35x18
If they don't have this set up, anything bigger will rub like crazy, anything lower offset will rub like crazy.
