broke two wheel studs
I just got my bbs Lm and tires today and I got home after mounting and balancing the tires. I broke two studs on my driver side front wheel. Broke.them while tightening them. I was searching around but didn't find any solid info, but would I need to bore my hub? are the rims not fitting right? Or did I use too much pressure when tightening? I only used one third of my weight.
You should be using a torque wrench when tightening wheel bolts/lug nuts. On the topic of wheel bore, what are the specs on your new LMs? You should be running hubcentric rings. We carry APR and Honda OEM wheel studs if you need help finding any.
Running 4 of the 5 lugs isn't that big of a problem. Not something I'd recommend but if you have to do it, you can. I wouldn't track the car like that though.
A $25 Harbor freight torque wrench is not a good investment, they have been proven to be +/- over 10% off the correct setting. If you want one relatively cheap the Craftsman works well and is within the industry standard for accuracy. The best option would be a professional item but they range from $300-600.
s2nasty03
07-05-2015 11:23 PM
dailodailo
10-18-2003 10:41 AM
