Are Bridgestone S03's the same size as '02
Are the Bridgestone S03's the exact same size as the oem S02's? Or would one need to get a larger rear tire if going with the S03's?
Originally Posted by xviper,Aug 22 2004, 10:40 PM
No other tire is the same as the OEM SO2. You'd need a 245/45/16 rear to be comparable.
How about the fronts? Are they BOTH 205/55/16 for S02's and S03's?
Read the sticky at the top of this forum for all you wanted to know about OEM and aftermarket tires for the OEM rims on the S2000.
Yes, select the same size fronts (205/55/16) and 245/45/16 for the rear when using Bridgestone SO3 Pole Position tires.
Call Jim at the Tire Rack. He'll make sure that you get the correct tires at a good price!
