Bought my wheels. Stern ST-8. Drop?
Old 09-08-2009 | 09:47 AM
snoodge's Avatar
Default Bought my wheels. Stern ST-8. Drop?
I bought 4 Stern ST-8 in hypersilver.
18x8 / 114.3 / +48 Offset all around.
Plan is to stretch a 205 width on the front tires and run 255 on the rears.
Only question I have now is, with an 8" wide rim and 48 offset in the front how much drop can the car tolerate without rubbing?
I would probably like 1-1.5" of drop. Will the Tein S springs do this?
Spring reccomendations?
Old 09-08-2009 | 10:44 AM
s2k dre's Avatar
Thats a normal offset for the front. Just run -1.5 camber. The 255 is gonna be pinched on a 8 inch wheel. 9 inch would be better on the rear.
Old 09-08-2009 | 11:27 AM
snoodge's Avatar
Are there any inexpensive camber kits that dont suck?
Would it be better to run 245 on the rear wheels?
Old 09-08-2009 | 11:44 AM
s2k dre's Avatar
Our cars dont need cmber kits. We have adjustable cmber front and rear. 245/35 would be nice. But make sure u match the front, u dont want a taller tire on the front.
Old 09-08-2009 | 11:46 AM
s2k dre's Avatar
look at these pics. Hes got the same size and offsets. Ask him what tires sizes hes got.
https://www.s2ki.com/forums/index.php?showtopic=727475
Old 09-08-2009 | 11:56 AM
snoodge's Avatar
It says in the post that he has 215 ZR18's. That seems a little too skinny to have on front/back.
I think im going to stagger the tires. My eventual plans are boost, and 215 width tires on the rear arent going to hold any power.
I think minimum I should be looking at 215's for the front and 245-255 in the rear.
I wanted to stay 40 for the height, but if its not going to work with an 18" rim I can go 35 height.
Old 09-08-2009 | 11:58 AM
snoodge's Avatar
Regarding the camber adjustment. My plan was to get the wheels and then take the car to a shop with a modern laser alignment. Would adjusting the camber be part of a normal alignment or do I have to take it to someone special to have the camber adjusted?
Old 09-08-2009 | 12:09 PM
DFWs2k's Avatar
come on, seriously? any shop that can do real alignments, can align the s2000
Old 09-08-2009 | 12:10 PM
snoodge's Avatar
I was just asking if adjustment of camber is part of a normal alignment. A simple yes or no would have done just fine.
Old 09-08-2009 | 12:24 PM
s2k dre's Avatar
camber caster and toe is part of a regular alignment.
Quick Reply: Bought my wheels. Stern ST-8. Drop?
