BEst Tire size ofr AP2
Ok I'm looking at a set of AP2 Wheels that need rear tires. I was told to check out Falken 452 in a 265/40/17.
How well do these tires hold up? I don't track the car. Not yet atleast. Just spirited driving.
Also are the good for up front also? Or should I run a 615 in front or Rs2? OR should the tires be the same on all 4 corners? What size should I run up front? Thanks.
BTW suspension is stock as of now. Locking to drop it soon. Coilovers most likely.
225/45/17 and 255/40/17 are a very popular size combination. Stock are 215/45 and 245/40. though the front measures closer to a 195 treadwidth-wise. One of our local autocrossers is quite quick on The 452's But I highly recommend Bridgestone RE 050A Pole Positions Or RE01R's if you can budget them.
