BBS RX 17x9 +28 offset all around...how do I fit?
So I just picked up a set of BBS RX wheels 17x9 with what I think is a 28 offset. the guy said 40. but I am not sure about that.
Anyways. Ido not want to have the ugly stretched tire look. I want prefrebly 235 or 245 in front and 255 or 265 rears with a 45 side wall...
Will this be tricky...what do i need to do to make the fit?
Thank you in advance!
Former Sponsor
If there are a 28mm offset they are not going to work. Even if they are a 40mm offset it is going to take a lot of work. You will need narrower tires, fender lip roll and negative camber to make it work. The 255 or 265 will not fit without pulling the fenders out.
so what would be my ideal offset goal to fit say a 265 in the rear? I have a 255 on my AP2 v1s and seems I could even go with a 265...so what is the problem with the BBS doing the same? thanks
CeleSaga83
03-30-2004 09:35 AM
