Baer OEM Replacement Drill/Slotted Rotors
I was looking at getting a set of these Baer Brakes replacement Drilled/Slotted Zinc rotors. Anyone have any experience with them, and if so what has been your experience so far. Thanks in advance for any help you can give. Thanks
You will not gain any performance from a slotted/drilled brake rotor on a modern day vented brake rotor setup. Its just for looks. You actually would have less of a contact patch under braking if you think about it. Plus they tend to be more prone to cracking.
Spitfire1976
04-06-2007 12:48 AM
