is it bad to run diff tires front and rear?
Old 07-28-2005, 05:06 PM
paS2K's Avatar
Originally Posted by paS2K,Jul 28 2005, 10:46 AM
Similar question: I have OEM S-02's on the front with good tread remaining (about 13,000 miles). I need to replace the rear S-02's now and would like to go with S-03's.
I think the improved 'rain driving' of the S-03's on the rear would be more impt than the slight degradation in handling due to mixed fronts/rears. Am I correct
Comments from anyone who has already done this would be appreciated....
Still would appreciate any other thoughts on this scenario....
Old 07-28-2005, 06:08 PM
Banned
Tugz_S2K's Avatar
Im still weary about mixing tires front and back. When ever you do this you upset the balance of the car. Putting different compound rubber front and rear.
As we know in the dry the S02 is better then the S03 in the dry
on the flip side, the S03 is better then the S02 in the rain.
So say you put S03's on the back with S02's in the front.
In the rain, because the S03's have better wet grip in the rear you may encounter
"push"/understeer (front end slides and does not want to turn).
In the dry, because the S02's have better dry grip in the front you may encounter
more oversteer (the back end spins out)
If you are a normal driver that dont drive with any aggressiveness then id say it would be ok. Im more concerned about the spirited drivers out there who like to push the car to the limit on turns and corners. Thats why on a car like the S2k, i think its best that all tires match. thats my $0.02
Old 07-29-2005, 11:59 AM
hpark's Avatar
no you don't have to change the tires......but you have to drive like your grandmother
Old 07-29-2005, 12:47 PM
aggie's Avatar
Not to call anyone out, but at local meets I see mismatched tire brands, no stagger, completely wrong diameters, and those cars are obviously OK to drive. In emergency or aggressive situations, you will be thankful for the proper setup though, so that is what most people here will recommend.
On a side note, I autocrossed a few times with s02 front/s03 rear (bought stock wheels that way) and the car felt the same as S02 all around.
Old 07-29-2005, 05:44 PM
paS2K's Avatar
Originally Posted by aggie,Jul 29 2005, 03:47 PM
.....On a side note, I autocrossed a few times with s02 front/s03 rear (bought stock wheels that way) and the car felt the same as S02 all around.
Thanks for this 'first hand experience' report That's the type of feedback that I was hoping for.....pro or con!
My car is in the shop at this moment (+$10k damage) due to over-ripe S-02's and water on the PA Turnpike. I don't want to replace them and have a repeat performance within the first couple of months....
Old 07-29-2005, 06:46 PM
meriggi's Avatar
just burn up the rear tires fast, then get a full set of some good tires!
Old 07-30-2005, 08:59 AM
d.h
d.h's Avatar
What about the same brand of tires, but different models front and back?
I was thinking Toyo T1R up front and Toyo RA1 in the back.
Old 08-10-2005, 02:00 PM
icecreamballer's Avatar
can u run wider tires on the stock rims? like wider in the both front and rear?
maybe 225 in the front and 245 in the back?
P5744D
07-05-2008 09:43 AM
cntcu
11-27-2005 12:53 PM
Joe04sk
05-18-2005 08:24 AM
JamesB
08-20-2002 11:04 AM
Quick Reply: is it bad to run diff tires front and rear?
