is it bad to run diff tires front and rear?
Old 07-27-2005, 04:28 PM
icecreamballer's Avatar
Default is it bad to run diff tires front and rear?
im currently running
Front: Kumho ECSTA supra 205/55ZR16 91W
Rear: Yokohama ACS ES100 225/50ZR16 92W
i have stock rims.. MY02 salvaged titled, every repaired back to original last july. and the tires are fairly new..
can somebody give me some advices? whether i need to change my tires? or not? or wat to do?
thnx!
Old 07-27-2005, 04:56 PM
Banned
Tugz_S2K's Avatar
Its bad to mix brands of tires on ANY car.....on top of that your rear tires are not the right size. They are too narrow. Only the OEM S02s are 225-50-16 for the rear. Anything aftermarket must be 245-45-16.
No wonder the car was totalled....
Old 07-27-2005, 05:07 PM
hrm.. i don know how im gona be able to buy new set of tires and get rid of the old tires.. i don think anybody would wanna buy them..
well the car was totalled with stock tires on.. its just that while they were fixing it, put random tires on.
i havent had any problems so far.. just the rear slips a lil wen i turn hard.
do u think this is a big problem?
also wat tires would u recommend?
thnx
Old 07-27-2005, 05:17 PM
Banned
Tugz_S2K's Avatar
The tires are the exact problem. Be careful or you will spin out.
I would change those tires quickly.
The cheapest thing to do is to just change the rears.
get a matching pair of Kumho Ecstas (same as front)
245-45-16.
The BEST thing to do is
Get a set of ORIGINAL S2000
Bridgestone S02's
205-55-16 Front
225-50-16 Rear
OR
get a set of
Toyo T1-R's or
Hankook RS-2ss
205-55-16 Front
245-45-16 Rear
Good Luck
Old 07-27-2005, 05:23 PM
hey is the oem S02 good??
Old 07-28-2005, 06:50 AM
john hood's Avatar
Depends on mixing tires. I have SO3's up front and SO2's in back. As soon as the SO2's wear out I'll replace with SO3's. Even with just the SO3 fronts the car is better in the rain.
Old 07-28-2005, 07:46 AM
paS2K's Avatar
Thumbs up
Similar question: I have OEM S-02's on the front with good tread remaining (about 13,000 miles). I need to replace the rear S-02's now and would like to go with S-03's.
I think the improved 'rain driving' of the S-03's on the rear would be more impt than the slight degradation in handling due to mixed fronts/rears. Am I correct
Comments from anyone who has already done this would be appreciated....
Old 07-28-2005, 08:09 AM
aggie's Avatar
I would change the rears to Kumho (712?) 245-45-16, then sell the ES100's on ebay, a local shop, or here. If they have good tread, they'll sell.
Old 07-28-2005, 09:27 AM
edbochung's Avatar
I've read good reviews for P Zero Nero M+S Ultra High Performance All-Season. I don't mind comprising dry handling for a longer tread life and quieter ride.
Go with this setup for these as well?
205-55-16 Front
245-45-16 Rear
How come only go with this setup for S02?
205-55-16 Front
225-50-16 Rear
Old 07-28-2005, 01:51 PM
aggie's Avatar
The stock S02 rear tires are much wider than any other 225's out there, so we go with 245 when using anything else.
Quick Reply: is it bad to run diff tires front and rear?
