Bad rim?
Old 01-08-2005 | 12:06 PM
Diablo99V's Avatar
Smile Bad rim?
About a month ago I got a flat. thats what I thought. Anyways they fixed it at a local tire repair place. Aftare a few days, a flat again. I took it again but this time they could not find the puncture or leak. I left the place and headed to a near firestone where they told me the air was leaking between the rim and tire Now I was lost even more. They used some special sealant and told me that it should be fine now. After a week the tire loses pressure again. WTF? at this point Im about to run the car into a canal. I took it again and they told me that the tires had to much tear & wear and that I needed new tires "pronto". So I ordered new Falkens 255 for the rear (btw this is the rear passanger with the problem) and decided to park the car until my new tires arrived so I didn't have to deal with the suffering any longer. When my tires arrived I took them to Firestone where they munted and balanced them, that was this past Monday. Im a happy guy at this point, until yesterday morning I feel the car a little funny and when I checked the pressure it had dropped to 17 psi. At this point I can't think of anything, can it be the rim? I don't think because I've had the car for almost a year and never hit the rim with anything. Im so WHat do u guys think this is? Anyone had this happen? I might go to the dealer and let them know because its really irritating me.
Thanx
Brute
Old 01-08-2005 | 01:28 PM
NFRs2000NYC's Avatar
You have a bent rim. (95%)
You have a leaky valvestem (5%)
Old 01-08-2005 | 04:17 PM
Diablo99V's Avatar
How can the rim be bent? Its like new!!! I will have the dealer check it out, hopefully the warranty will cover it.
Thanx.
Oh the valvestem was changed when the new tires where installed.
Old 01-09-2005 | 05:54 AM
SLO S2k's Avatar
I hear that all the time.....I didn't hit anything. It doesn't take much, consider the road construction, potholes, manhole covers etc that can cause problems...
Old 01-09-2005 | 11:35 AM
revhi's Avatar
If the rim was bent, they would have seen it when mounting. Stop going to Firestone.
Old 01-09-2005 | 04:14 PM
SLO S2k's Avatar
More like should have seen it......alot of companies don't even look at the wheel while it's spinning on the balancer
Old 01-09-2005 | 06:22 PM
revhi's Avatar
A bent rim would really throw off the balancer machine. You would have like a pound of weights on the one part. I think they would find that fishy.
Old 01-09-2005 | 10:32 PM
SIIK2NR's Avatar
Is the car garaged? You think someone might be messing with you???? ie. letting the air out?
Old 01-10-2005 | 04:30 PM
Diablo99V's Avatar
I already made sure it was not someone messing with me I got to many friends that can't live without a joke but I got that end covered. I will just take it to the dealer as soon as I can and make them check it out and replace the rim if anyting is wrong with it. Does the warranty cover this?
Old 01-10-2005 | 04:37 PM
revhi's Avatar
Probably not since they arent the stock tires and someone else has swapped them.
AZS2KDancer
12-07-2017 02:17 PM
CHUCKLIDDELL101
05-09-2010 08:32 PM
s2000bkny
03-05-2004 02:17 PM
MyBad
06-17-2002 06:35 AM
sweetj
05-11-2002 12:56 PM
