axis hiro wheels or similar alternative
Old 07-01-2007 | 05:44 PM
  #21
Ubetit's Avatar
Originally Posted by tampas2000,Jul 1 2007, 10:25 AM
the rear can actually handle 275/35 with no problem
Sure it can. No problem at all.
Old 07-01-2007 | 05:55 PM
  #22
IIGQ4U's Avatar
Originally Posted by Ubetit,Jul 1 2007, 04:42 PM
Maybe with a guarantee like that you'll buy them after he rubs. He will rub.
Ubetit, he will not rub unless there is a problem besides the offsets.
I am currently running an 8" front and a 9" rear wheel with a 45mm offset all the way around and I do not rub. I am also lowered a fair amount. The original poster's setup is not at all aggressive. I know for a fact that he will not rub unless he is running a fair amount of POSITIVE camber. -2 negative camber in the rear and -1 up front and he should have no issues unless those 18" tires are a lot taller than 17s.
I would be more than happy to post some photos of my +45 setup.
Old 07-01-2007 | 06:21 PM
  #23
Ubetit's Avatar
Go to the main Wheel and tire forum page and type rubbing at the bottom in the search box. The problems all start at about +48 and get worse through +35 needing wider fenders. I see many problems with +45 fronts.
Sure you can do a bunch of modifications and roll around with your wheels looking like this /------\ from -3.5 deg of camber or make your teeth chatter from 12k springs. ... but why would you? I've rubbed a +50 at stock height no way in hell i'd run a +42 in front or small tires like a 235 in the rear.
Old 07-01-2007 | 07:57 PM
  #24
IIGQ4U's Avatar
I am personally only running -1 degree negative camber in the front and -3 in the rear for the track but have not aligned my car since my last event. I will clear with between -2 and -2.5 rear camber. I have not rolled or flared any of my fenders (If you are too low, you risk damaging your fenders if you turn into a driveway improperly. I believe this to be due to caster). I am also only running a 400lb. front spring and 340lb. rear (My KW track coilovers are another story).
I can barely believe that you rubbed at stock height with a +50 offset, that is just insane! I would imagine that under the most extreme cornering you can rub at almost any offset/height. It is amazing the mixed results with various offsets.
Old 07-01-2007 | 09:45 PM
  #25
-DOZER-'s Avatar
Originally Posted by tampas2000,Jul 1 2007, 06:25 AM
i have the reverbs on my S
18x7.5 +42.. 225/40/18
18x9.5 +55.. 255/35/18
no rubbing what so ever.. i am dropped on tien s tech spring.. if i go lower i need a 215/40/18 for the front...... the rear can actually handle 275/35 with no problem
Any more pics of your car with wheels?
Old 07-01-2007 | 10:08 PM
  #26
beesting's Avatar
nice one
great to know this setup is working for you. would love to see more pics of your car!
thanks again mate.
Old 07-01-2007 | 10:32 PM
  #27
IIGQ4U's Avatar
It can work for you too!
Old 07-02-2007 | 04:55 AM
  #28
tampas2000's Avatar
if you click on the image it will link you to the sight that host all of my pics
Old 07-02-2007 | 10:01 AM
  #29
-DOZER-'s Avatar
Dude, your pretty brave running an AEM V2 in Tampa, FL. I can see the storm cloulds in the back ground!
Nice wheels though! Did you look at the grey option or just wanted black?
Old 07-02-2007 | 07:27 PM
  #30
tampas2000's Avatar
yea i know about the weather here.. i actually took off the AEM v2 off and am trying it to sell it..i actually prefer the black over the grey... there is another guy here in tampa that has silverstone with the anthrocite wheels... i am contemplating getting the lip powder coated red... what do you guys think of the this wheel with a red lip
