Ax tire contact
Old 03-10-2024 | 10:59 AM
Dibsen's Avatar
Default Ax tire contact
Hey Team,
looking to get some feedback on my tire contact. Car felt great, I had considered dropping down to 28psi for a little more contact but I was focusing on my skills and less on the car and setting.
Really pleased with the new tires. Not something I was expecting but the ride comfort is great. Grip is obviously amazing and they gave great indications and warning when they where getting to their limit.
Front left tire. I ran 30psi front and rear. I’ll have to go back to find my alignment specs but I used RobRobs suggested settings.
Front left again, on the inside.
Rear left. My thumb is the farthest wear mark.
Rear left. You can see the contact pretty clear.
Old 03-10-2024 | 07:42 PM
hai1206vn's Avatar
What's your tire size? Square 225?
What alignment spec? At stock height you can get at most -1.7 deg camber up front. Rear should be set around -2.0 to -2.3.
Your front tires should wear more than rear tires, because of less static camber, AND the front camber gain on compression is also less. In photo #1, front & rear wear look similar, so you're probably running too little rear camber.
To limit front camber wear, the only thing you can do in street class is use a bigger front sway bar to reduce roll.
My setup some years back (MY2002), running Dunlop Direzza ZIII tires:
- Front: -1.7* camber, 0 toe, 1.25" Gendron hollow bar on 4th hole.
- Rear: -2.0* camber, 0.15* toe in (0.30* total)
Old 03-12-2024 | 02:50 AM
Dibsen's Avatar
225 square. Below are the notes I passed to my shop and the results.
Pulled these from RobRobinett
Wondering if I should increase rear neg camber?
Old 03-12-2024 | 05:45 PM
hai1206vn's Avatar
Yes,
The CR in this thread runs -2.3* rear: https://www.s2ki.com/forums/s2000-ra...hread-1115799/
C6400hp
11-08-2005 02:13 PM
ras2k
08-03-2005 02:05 PM
NYMATT74
12-20-2004 12:20 PM
petouche
06-24-2003 07:24 AM
KeithD
01-18-2003 04:19 AM
Quick Reply: Ax tire contact
