AP2 Wheels and Wheel Spacers
does anyone have any pictures of this being done? AP2 wheels with 10mm or 15mm spacers? im thinking about doing this but i need to see how it would before i go out and buy it.
I was thinking about doing this as well with my AP1 (I have AP2 wheels)...I just want the wheels to come out a few MMs more...I figured maybe a 15mm spacer would do it, but from the sounds of it, I'd need to install extended studs for them to work (which I don't want to have to deal with)...
I did find this thread where 'efthimios' had a pic of his AP2 with 25mm spacers: https://www.s2ki.com/forums/index.php?showt...16588&hl=spacer
The wheels stuck out a little further than I would've liked though...perhaps a 20mm spacer would be better (to keep from rubbing)...but does anybody know if the 20mm spacers require extended studs, or if they come with the studs already on them?
[QUOTE=73Zero,Oct 9 2006, 11:10 AM]I was thinking about doing this as well with my AP1 (I have AP2 wheels)...I just want the wheels to come out a few MMs more...I figured maybe a 15mm spacer would do it, but from the sounds of it, I'd need to install extended studs for them to work (which I don't want to have to deal with)...
i don't seem to like the look of 25mm to much seems like they stick out way to far. also you run into problems with your wheel bearings if such a wheel spacer is used. i don't know, i could be wrong.
bump also for the 10mm or 15mm
bringing it back.. does anyone have a picture of ap2 wheels with 20mm spacers? going to buy it soon, debating between 15 or 20mm
im thinking about going w/ project kics 20mm all around, but they don't seem to have the center hub ring for the front (i think 70.1mm or 70.7 i've seen different numbers) is this going to cause problems? or should i just go with 25mm h&r hub centric, and re-adjust my camber so it doesn't rub.
i need input please....
i have 17mm hub centric spacers... with ap2 wheels. and they are flush with my fenders. and clears the stoptech bbk.
20 or 25 will look out of place... 15 will not clear larger bbks.
