AP1 wheels on a AP2
Old 02-16-2009 | 10:35 AM
F22Cast's Avatar
Default AP1 wheels on a AP2
I have a nice set of AP1 wheels and i was wondering if these smaller 16" wheels with 205 in the front and 225 in the rear will cause strain on my F22?
Old 02-16-2009 | 12:16 PM
1nate7's Avatar
No problem, they will be fine.
Old 02-17-2009 | 11:05 AM
dparm's Avatar
I run AP1-size wheels on my winter tires, there's no problem at all.
Old 02-17-2009 | 03:47 PM
DougEFresh's Avatar
less strain..less rotating mass, though oem offsets will make your handling suffer.
Old 02-18-2009 | 03:36 AM
ZDan's Avatar
AP1 and AP2 offsets are the same, so I don't see how that would affect handling...
Handling will be similar with slightly less ultimate dry grip (on the same tire make/model) due to less tread width.
No more "strain" on your engine, AP1 and AP2 tire diameters are nearly identical, rpm at speed remains approximately the same.
Old 02-18-2009 | 04:37 AM
mjschrage's Avatar
It will change the gearing ratio, thus making it feel like you have more gear. Stock 4.1 > 4.3/4.4
Old 02-18-2009 | 06:30 AM
ZDan's Avatar
It will NOT change the gearing ratio. The AP1 and AP2 tire diameters are near-identical, the AP2 tires being 1% smaller in diameter. So with AP1 tires you'll be geared ever-so-slightly taller, as if you went from 4.1:1 to 4.06:1. Not many people would notice that even with GPS.
Old 02-18-2009 | 09:41 AM
Boost76's Avatar
You will gain 100hp with AP1 wheels.
Old 02-19-2009 | 02:52 AM
Dr.Troy's Avatar
lol at last post
Old 02-19-2009 | 11:53 AM
mjschrage's Avatar
17's and 16's will give you a noticible gearing change.....thats the end of that. But it really depends on the rubber you put on the 16's when it comes down to it.
