View Poll Results: Which tires should I buy?
Voters: 31. You may not vote on this poll
AP1 - stock size tires on stock size wheels
If you're going to start AutoX and tracking your car, save some money and just buy four 17x9 TR Motorsport C3s and go with either 255/40 or 245/40 on all four corners. I'd recommend the Dunlop Z1 Star Specs as the best value for the mixed use you are looking at.
You can buy other tires for your 16" rims now, but, you'll want to upgrade them quick. If you had an '00, '01 or CR, I'd have different advice, but, your '03 is going to be more competitive in STR than in B Stock. So you might as well just move that way now.
As a side note eventually you'll want a stiffer front sway bar, but, in the interim you can disconnect your rear bar to compensate for the increased front grip of going to a square tire set up.
edit: see you already picked up just 2 rears, so just keep this in mind for next year, hope to see you around
I think you made the correct choice with the S02 and matching the fronts. The next time you will have both of them wear out together and you can make a tire choice to suit your needs. The S02 is a great handling tire on the car though so they will be fine on an autcross. The RS3, Star Spec, RE11 and the Yoko Neova are evem more Extreme almost track tires for the street.
If I can help just let me know.
here is my take on the situation. I think the S-02's on stock wheels are a great tire for just starting out at autox, enough grip to be fun, but unforgiving enough for you to learn.
I do agree with eventually getting a bigger front bar but disagree about disconnecting the rear bar on oem suspension especially since you still have staggered tires. it will greatly increase body roll.
I would say if you decide you really like autox and want to get more involved in it then start with a big adjustable front sway bar (Saner or Gendron) and the 17x9 +60 or +63 with RS3's. For dry performance in warm conditions, the RS3 is the top dog, and luckily happens to be one of the cheapest tires in that category.
Like most of the people on this thread, I too recommend the Dunlop Star Spec or the Hankook RS3. I've run Star Specs for the last two autocross seasons, and I've been pleased with the grip and the responsiveness. They also last a long time for such a high performance tire. If you want to go slightly less extreme than the above choices, I've heard the Hankook V12 Evo is a pretty good summer tire as well.
I hate Kumho, just my opinion but they're not worth the slight savings, they are crap. Zero grip, caused an accident in one of my cars just because it was a slight mist and i was taking a right turn over 10mph.. Slid straight into the median, it was such a slow speed for traction loss i had time to think "woooooooooooooow, thiiiiis isssss bulllllsshhhhiiiiiiit" and BAM! Never doing Kumho again
I picked up two S-02's for the rear just to keep things simple since my front ones are in such good shape.
I'll get one of the options from the OP when I go to change all four tires in 2012 or 2013. Thanks for all your help, guys. My next tire purchasing decision will be a lot easier.
