ap1 oem wheels/tires (psi should be) ?
what psi do i set my oem ap1 tires ? i live in northern california temp is around 70-80 normal...90+ ahhh it happens ... i have it at 40psi should i change it? thanks!
Door sticker usually is for softest ride.
Tire manufacture puts a recommended max load tire pressure on the sidewall of the tire.
I usually find a pressure between the two that gives best performance.
Depends on how you want the car to handle, how you much you care about tire wear and ride comfort. For best handling I ran my tires about 36 PSI front and 34 rear. Rears wore down the middle from over inflation. Fronts wore about perfect.
