Anyone running 225/40/17 in front ?
I would not do it personally. The sidewall will be shorter by 6.75" which would mean over half an inch smaller overall diameter. Plus, what would you run in rear? Different model tires? Tires are not anything to cheap out on.
i am picky about tires and usually dont go cheap, but its a really good deal....
Sidewalls for 225/40-17 will be shorter than 225/45-17 by .05*225mm, or 11.25mm, just under 1/2". Difference in diameter will(obviously!) be twice this amount, or just under an inch.
Agree with the point regarding running compatible front/rear tires.
Q for op: what make and specific model tire are youfinding in225/40-17, and what make/specific model and size rears would you be running them with?
