Any risks running spacers?
Just wondering if there are any risks running spacers that I should be concern with. I will want to eventually track with them. Don't want me wheels to fly off! haha.
should be no problem as long as the spacers aren't too thick. I have 5mm spacers on the rears without any problem but anything bigger extended stud is recommended.
I'm running 20mm and 25mm spacers and I have done one track day and 1 auto x event. No problems what so ever. As long as they're torqued properly you will be A-OK!
Thanks for the comments...I am still a little insecure, so I might google the risks involved w/ spacers. I plan on running extended studs 25mm...either Ichina or H&Rs.
depends on what spacers you run.
if your going anything with a +15 or more, buy the ones with studs. anything under a +15 then buy extended studs and have fun.
all depends on torque specs and how you drive your car, but you should be fine.
look into POWERED BY MAX
http://www.gtfactory.jp/cms/page.php?10
thank me later
thank me later
i dont have any personal experience with them but i havent heard anything bad about them. My friend used one of theyre hub conversions on his 240 and they were good quality.
