Any autocross wheels available?
Jim, are there any lightweight aftermarket wheels readily available that match the dimension and offset of the stock S rims? This is an autocross question so offset can be off by 1/4 inch, preferably to the outside.
Have you tried http://www.kodiakracingwheels.com/
They will make any wheel diameter, width, offset. Meaning you could get OEM specs and play with the 1/4" rule.
Not sure about weight. ~$375 per wheel.
In reading the SCCA rules I see no reason why they could not be used.
Does anyone else know?
[QUOTE]Originally posted by laedwards
[B]Have you tried http://www.kodiakracingwheels.com/
