Another "will it fit" question
Old 08-01-2009 | 03:53 AM
b1indsamurai's Avatar
Default Another "will it fit" question
Hey guys, I'm lookin at a set of Gram Light 57s's that were previously on a NSX.
Specs:
front -- 18x8 +40 offset
rear -- 18x9.5 +38 offset
Will these fit with stock height and no modifications to the body? Or will I have to roll/flare the fenders
Sorry, I'm a complete noob when it comes to wheels
edit: Forgot to mention that I have a CR, if that effects anything.
Old 08-01-2009 | 05:22 AM
CU Nick's Avatar
You will deffinately need to roll the rears and most likely the front depending on what size tire you plan to run. You'll also be in the -3 degree of camber playing field to fit the rears. I suppose you could run more camber negative camber instead of rolling your fenders, but what would be the point?
You might want to consider lowering the car as well...
Old 08-01-2009 | 12:45 PM
Jim@tirerack's Avatar
Former Sponsor
It would be some work to make this application fit. It would be very aggressive in the rear. You would want to stay narrow with the tires. You would also want to check on the center bore.
Old 08-01-2009 | 02:06 PM
Thanks Nick and Jim!
I'll probably pass on these...
pjf1985
12-15-2013 11:41 AM
panta
04-01-2012 05:17 PM
Drkphnx
03-04-2012 11:18 AM
chiney_dolly
04-20-2009 01:21 PM
lilmrtinnie
03-29-2007 03:47 PM
